rattling from engine bay! help!
Old May 17, 2002 | 08:00 PM
woody86's Avatar
when ever the rpm's go up or down, like taking off from a stop or making one, my engine makes a soung like someone shaking a tin can full of b-b's. it sounds like it's coming from either the top or front of the engine, but i can't pinpoint it. could it possibly be a loose timing chain? please help!
Old May 17, 2002 | 08:04 PM
Wolfpack's Avatar
Car: 86 Iroc
The last time i heard somthing like that it turned out to be a heat shield on an exhoust manifold...but that was on a 4 bangers...as for the timing chain..i don't know i just thought when they went they went...Good Luck though
Old May 17, 2002 | 08:20 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yeah, the heat shield on my headers or something makes an annoying rattle on my car.
Old May 17, 2002 | 08:45 PM
woody86's Avatar
yeah i thought of that. when i try to wiggle the heat shields with my hand, they don't move though. i tried checking all the brackets and everything!
Old May 18, 2002 | 07:55 AM
1986redbird's Avatar
Woody, you didn't say if you had a cat or not, but if you do, sometimes the core in the cat will come apart in the cat and sounds just like you describe, also if you still have the exhaust diverter valve in the system (hooked up in line under the passenger exhaust maniflod) make sure the actuator rod is still hooked up to the butterfly valve, if not, it will rattle whenever you change rpm's.
Old May 18, 2002 | 08:23 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
are you sure its not pinging? put better gas in it
Orr89RocZ
Apr 25, 2016 08:28 AM
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
