Engine weight reference
Old May 17, 2002 | 09:58 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I stumbled across an article about engine weights. All engines were weighed complete from carb to pan, HEI distributor, harmonic balancer and an iron water pump.
Factory SBC, iron heads etc = 520 pounds
SBC with aluminum heads = 480 pounds
Factory BBC, iron heads etc = 754 pounds
BBC with aluminum heads = 660 pounds
All aluminum ZL-1 501 pounds
They never did weights with aluminum intake manifolds. An aluminum BBC intake is a greater weight reduction than an aluminum SBC intake. Going to a mini starter will be equal on both engines. Swapping cast iron exhaust manifolds to headers cuts more weight since BBC exhaust manifolds are much heavier than SBC manifolds.
Old May 18, 2002 | 03:47 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
You said the magic word to set me off on a tnagent tonight.... Mini-starter... They're junk...
I first tried a http://www.tommmyjohnsonjr.com/bs starter. Its a large flywheel offset pattern... anyway 3 starts and the SOB sticks on and gets wiped in less time than..{ed}
OK then I get a GM style starter that cranks it over 3 times. I sent it back to get a replacement but never put it on, just got a stocker which I must of started 8000x so far.
Is it just me?
customblackbird
Aug 15, 2021 10:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
E Rod
Aug 28, 2015 05:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
