question about wiring when i go TBI to carb on new motor
Old May 20, 2002 | 07:00 PM
TBI305Camaro's Avatar
ok im hoping to get a lo5 this summer (not a real performer but at least its a 350 and brand new for cheap) anways...how can i do away with the wiring harness completely? can i get a one wire alternator and run the wire to the starter? will i still have use of my gauges and techs? i dont want that huge wiring harness there unless it has to be. i guess it will tho so the heater motor will run and everything. does anyone have engine pics after TBI to carb swap? that may help alot
Old May 20, 2002 | 07:16 PM
gtabadboy's Avatar
The safest way is to just tuck the harness under the passenger fender. This is what I did and all my gauges work fine, not to mention the fuel pump and VATS on my key. I went from TPI to carb. The only thing that you have to do is wire your fans different. Im not sure the best way so I wont give you bad advice.
Old May 20, 2002 | 10:08 PM
my fan is on a switch right now anyways so that should work fine. i rarely have to flip the switch anyways. im really wondering about the starter wires, alternator wires, and battery wires and stuff thats really important like that
Old May 20, 2002 | 10:31 PM
gtabadboy's Avatar
What I did is left everything alone and just hid the harness. Everything will start just fine. You will need a new distributor that is not computer operated and just hook up the ignition line from the harness (should be red or pink). Other than that you will need a mallory regulator if you plan to keep your stock fuel pump. Call Summit tech. Those guys are great. 1-330-630-0240
Old May 21, 2002 | 10:30 AM
is the harness is more than one piece? to keep the alternator hooked up the huge harness will have to stay on top of the motor which i dont want
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
redmaroz
Aug 16, 2015 11:40 PM
