Air injection hose routing???
Old May 20, 2002 | 09:52 PM
Nuclear Ape's Avatar
Question for all, I am a little stumped on how to route my air injection from the passenger side to the drivers side...
I know the factory way is to go around the back of the block, but I am building up a motor and want to change it...
Any ideas on what I could use and how or where to route it??
Thanks for all your help...
p.s I also should say that I've got tall valve covers...
Old May 21, 2002 | 12:04 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
You could route it down around the front of the oil pan and then back up the other side just like the oil cooler lines.
Old May 21, 2002 | 09:05 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
The factory way wasn't ALWAYS around the back of the block. Stock routing on my 84 was in front of the carb.
Old May 21, 2002 | 11:29 AM
Vader's Avatar
...and just like the LT1 A.I.R. tube routing. Maybe you could grab a set of tubes from an LT1 or L99 in the boneyard - the engines are externally identical.
Old May 21, 2002 | 11:55 AM
Vader thats a good idea....
I'll have to give it a try...
And the idea of around the carb won't work as I've got TPI and It just doesn't look good over the middle...
Thx
Old May 21, 2002 | 11:57 AM
99Hawk120's Avatar
Well, you didn't post your motor, so sorry for assuming there might be a CHANCE you had TBI...
Don't worry about it. I was just making a point.
1992 Trans Am
May 10, 2023 07:19 PM
1fast91
Sep 8, 2015 01:48 PM
z28addict8490
Sep 5, 2015 03:56 PM
dyeager535
Aug 28, 2015 08:10 AM
BurlyChev
Aug 22, 2015 01:52 PM
