Best sealing for chrome valve covers?
Old May 20, 2002 | 12:46 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I've heard that the chrome is too slippery for the gasket to seal, and that the sealing area should be scuffed with a fine grit paper, in order to roughen up the chrome. True?
I'm thinking of throwing on chrome valve covers when I rebuild my motor; I like the aluminum ones I have now, but chrome would be spiffy. But either way, I'd have to take the covers off, and put covers back on. Should I use the cork gasket? Should I cover the cork gasket in blue RTV? Should I skip the cork gasket and just use RTV? I don't think any "performance" valve cover gaskets are made for my 2.8 V6!
Old May 20, 2002 | 02:00 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
i'm using 100% rubber gaskets with my chrome covers and after a couple months of my engine running, they're still not leaking.
Old May 20, 2002 | 02:01 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Regular Fel-Pro gaskets with some RTV sealant will do the trick.
Old May 20, 2002 | 04:56 PM
Fast3rdGen's Avatar
fel-pro rubber gaskets.
Old May 21, 2002 | 06:42 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
fel-pro here...just be sure not to over torque...and give the sealant time to set....
Old May 21, 2002 | 09:10 AM
92blackbird's Avatar
Car: 1992 pontiac firebird
Engine: 305 tbi
I agree, the rubber gaskets work fine w/o rtv. and they're reusable a few times. Did the chrome covers about 2 months ago, no leaks but I do check to make sure the wing bolts haven't loosened.
Old May 21, 2002 | 09:42 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Thanks for the replies, guys! I'm 99% sure that there are NO rubber gaskets for my application (2.8 V6)... so unless I dig up a part # (and I'll look), it'll either be cork, rtv, or a mixture of the both. Which is better? Or do they all suck just as bad?
Old May 21, 2002 | 12:11 PM
Morley's Avatar
Might want to try some Permatex Hi-Tac on the gaskets. That stuff seems to stick better to very smooth surfaces than RTV does. RTV will stick but can be peeled off easily in almost a single piece (like using it on glass), the Hi-Tac won't peel off (you'll need solvent to remove it). I could never get my chrome valve covers to seal for longer than maybe 6 months, till I tried this stuff.
~M~
db057
Sep 4, 2015 07:57 AM
Thaney9
Aug 29, 2015 03:16 PM
NBrehm
Aug 25, 2015 11:49 PM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 8, 2015 01:18 AM
