Starter, flywheel problems...
Old May 22, 2002 | 10:04 AM
zboss86's Avatar
I'm sure everybody has heard the horrible grinding noise of the starter and flywheel hitting wrong.
Well I got one those problems... It does it every 10 or so cranks, but when it does it's embarrasing as hell. It's not hanging up, it's just grinding every now and then.
I still got all my flywheel teeth and bendix teeth for now...
Will shimming the starter fix this?
What's the clearnce between the teeth of the flywheel and the teeth of the bendix suppose to be. I think you can get feeler gauge and check this can't ya?
Old May 22, 2002 | 12:52 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I too have suffered from this type of problem, with several chevys over the years.Shimming it will probably just make it worse, unless the gear is too close to fully engage the ring gear.
The gap is tough to measure with the trans installed (or bellhousing), but if you can get in there, a paper clip should just fit between the teeth.
-Rich-
Old May 22, 2002 | 04:25 PM
88camaro's Avatar
i think it might be a worn starter, or flywheel teeth, and the grinding sound might be starter teeth missing the flywheel teeth (ie. not catching them). i've replaced a starter and the flywheel teeth on an old volvo that did that for a friend of mine.
what you can try and do is tighten up the bolts holding the starter up, cuz them being a bit loose will also cause teh condition you described
just my .02 cents
Old May 22, 2002 | 04:32 PM
tpi_roc's Avatar
Mannnnnn
That aint nothing
I just installed my new engine/tranny combo that i've been working on for months (as money permitted) and found out while I was putting on the final touches last night (starter) when I realized I was sold the wrong flexplate!!
I had to tear down to change it......
So be glad your starter problems aren't WORSE
3rd gen money
Oct 11, 2019 09:57 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
