Rough Idle.....When Warm
Old May 23, 2002 | 01:01 AM
indocld's Avatar
I Have A 91 Camaro Z-28 (305 TPI 5 Speed) When The Car Warms Up It Starts To Idle Rough, Fluctuating Between 500-900 RPM's And Sometimes It Will Die. The car Has Had A Full Tune up About A Month Ago And A New O2 and TPS sensor.........Thanks For Any Help...................Also Some Fluctuating When Held Steady At Higher RPM's +/- 200
Old May 23, 2002 | 02:24 AM
blk91z28's Avatar
Old May 23, 2002 | 02:26 AM
blk91z28's Avatar
Maybe the IAC valve is sticking or dirty,might need to be replaced.
It's under the tps sensor going into the valve body side ways.
Old May 24, 2002 | 09:01 AM
Vader's Avatar
It may be a good idea to do a power balance test on the injectors.
Old May 24, 2002 | 09:19 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Testing the resistance on the injectors when cold and warm should also help you rule them out.
I had the same problem and found 2 bad injectors.
Reid Fleming
Oct 10, 2015 09:56 PM
HoosierinWA
Oct 7, 2015 10:15 AM
thejimsterz28
Sep 30, 2015 08:52 PM
Jlanz55
Sep 29, 2015 08:55 AM
mfp189
Sep 27, 2015 09:25 AM
