Aluminum heads question???
Old May 23, 2002 | 11:50 AM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
I recently bought a set of Trick Flows 23 degree heads (aluminum). My question is, can I use FEL PRO 1094 .015 compressed head gaskets with this head? I read some where that aluminum heads need "special" head gaskets. Any comments?
njdaewoo
Old May 23, 2002 | 12:22 PM
urbman's Avatar
There are a couple of thoughts on this...
Aluminum will act as an anode to virtually all other metals
except zinc and magnesium and so will always tend to
sacrifice itself (as a battery anode).
Sooo... "special gaskets" are either non metalic or
are coated with zinc.
As to whether you can use FEL PRO 1094 .015 gaskets...
Sorry... Don't have a set...
Old May 23, 2002 | 12:52 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
It's true that aluminum heads do need a special gasket. The usual head gasket is a FelPro 1010. It is .037 inches thick. The difference is that gaskets designed for an aluminum head use a copper wire ring instead of steel. A normal head gasket designed for an iron head will cut a groove into the aluminum in a ring around the combustion chamber.
Old May 23, 2002 | 10:08 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
just what vicious said. they call the indentation brinelling. are the 1094 gaskets actually gaskets or just shims? i've heard shims are crap.
midge54
Dec 27, 2019 04:14 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
redmaroz
Aug 16, 2015 11:40 PM
