FUEL pump, 86 LB9
Old May 23, 2002 | 04:04 PM
madmachine's Avatar
FUEL pump, 86 LB9
Car has sat for two years, and even when shorting the diagnostic terminal, the pump won't kick on. The fuse on the passange fender is good.
What would you guys do? PS- The gas needle won't even move.
Old May 23, 2002 | 05:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'd get a multimeter and check for voltage and continuity/resistance, starting back at the sending unit connector.
Old May 23, 2002 | 05:45 PM
madmachine's Avatar
8.5 volts at middle connector.... is that what the voltage is suppost to be reduced down too?
Old May 24, 2002 | 08:41 AM
madmachine's Avatar
Hello everybody.... I need to know if 8.5 volts is the proper voltage so I know if I'm looking at repairing my fuel pump, or age wiring.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
gta90
Sep 15, 2015 04:00 PM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
