Have To Pull Timing Chain Cover Sunday Few Questions
hey all my new motor has sprung a little leak so i am changing the timing chain cover gasket and the front oil pan gasket seems that is the section that the oil is coming from.. anyways wheni pull the balancer off how hard is it to put it back on actually how do u put them back on?? pound them on or slide it on and tighten the pulley down does that move it back?? never pulled one and had to put it back on.. thanks for the help..
Put the balancer in the oven at around 200 degrees (no higher) for an hour or so and put it on hot (wear gloves), you may have to tap it on, BUT if you have to hit it hard to get it to seat, DON'T, go get a harmonic balancer installer. Most of the better auto parts stores carry them.
~M~
~M~
Moroso, Tavia, and others make a tool to install the damper correctly. You may even be able to rent one at your local parts house. Do not try to hammer it on or try to pull it up with the damper bolt.
Lonnie
Lonnie
Dos Ponchos,
That "harmonic balancer installer" consists of a 7/16-20 threaded rod, 5" long or longer, a 7/16-20 nut, a washer, and a large drift (socket or the thick washer from your balancer bolt) to spread the load. If you can't find a dedicated "installer", you can assemble one from those parts, which should be available from any good hardware store.
Don't hammer it on, please. And don't try to use the original bolt to install the hub. I'm not ready for another one of those "Oh, Crap! I stripped my crankshaft!" type threads on the Tech board.
Before installing the balancer, rub some clean petroleum jelly (Vaseline) on the outer hub that will contact the seal so that the new seal doesn't get damaged on installation or from running dry on start up.
You do know that you will have to lower the front of the oil pan to install the timing cover lower seal, right? And generous amounts of sensor-safe RTV sealant on the ends of the timing cover lower seal will complete the seal nicely.
yep that i know lots of rtv sealent!!! hope this stops the leak thats all i got to say pretty embarrising leaking oil frm a newly built motor.. infact it kindof pisses me off to tell you the truth lol
Originally posted by 2ponchos
i am sure auto zone has one i can rent but can i pull it with a pulley puller?
Go get a balancer puller. Discount auto carries them for about $15.
~M~
got it done today!! took the most part of the day but its done.. was pretty easy to do used a balancer puller and the balancer reinstalled just pushing it back on.. but as far as i can tell no drips.. leaks or anything!! happy bout that.. so tuesday going to the guy who built the motor and handing him a bill..lol but thanks for the help guys
Originally posted by 83z28500ci
i striped my crank 3 times, had to go out and buy a tap. if u do strip it, tap it and get a couple bolts at home depot for like 30 cents each, instead of the 7 doller 1;s at the local speed shop
Just make sure those Home Depot bolts are graded '6' or better. And be very careful of imported fasteners, regardless of how they are grade marked. That's what the Fastener Quality Act of 1993 is all about - cheap imports (and even domestics) intentionally mis-marking critical fasteners for more profit.
Could you tell? I used to be in the business.
I'm going to be taking my timing chain cover apart because I just redid the gaskets but my stupid ex boyfriend's dad decided to cut the sides of the lip for the oil pan gasket. Anyone here ever cut that part?? I'm pretty sure your not suppose to either. Because I've got a pretty bad oil leak now. I'm glad i read the info about that balancer...I was always told to just beat it on with a hammer...but then again that info was supplied from the same person who cut my cover...did I mention that I wasn't there when he did it...and that he still wasn't able to get it on after he did it but I got it on just in seconds...sigh
Anyways...any other tips on taking apart the cover??
Car: www.hrfbody.com
Engine: www.hrfbody.com
Mike no you didn't...when was this thread made??? IN MAY!!!! omg...are you that immature that you are going through my old threads so that you can call me a liar...I'm sure this board doesn't need your drama just like the rest of the boards....
Car: 99 Formula
Axle/Gears: 342
backtothe80s
Sep 5, 2015 12:39 AM
