Which is the better intake?
Old May 28, 2002 | 11:35 AM
mefreema's Avatar
Which is the better intake? The Weiand Action Plus or the Edelbrock Performer? I am leaning toward the Weiand because it has a 0-6000 rpm range as apposed to the edelbrock 0-5500 rpm range. Which intake is better or makes more power? Thanks!
Old May 28, 2002 | 12:17 PM
camaro6spd's Avatar
power at 0?
I have always wondered y company post that their intakes make power at 0 - XXXX RPM.....as far as i know no matter what you d to an engine 0 RPMs is not gonna make any power......the enginei s not spinning.... .00005 would make power....not sure what it could do.
Old May 28, 2002 | 12:22 PM
mefreema's Avatar
Let me correct myself! Weiand Idle-6000 and Edelbrock Idle-5500 Anyone? Anyone?
Old May 28, 2002 | 12:49 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
What's your setup? Depending on it, maybe look into the Edelbrock RPM 1500-6500. Or if you only want power to 5500, I would get the Performer EPS, it's new with improved HP/TQ over the reg. Performer.
Old May 28, 2002 | 01:01 PM
Jester's Avatar
Wieand Stealth.
Old May 28, 2002 | 01:05 PM
mefreema's Avatar
Intake need to be a spread bore so I'm stuck between those intakes pretty much. Still have not picked out a cam so I'm not sure. May pick a cam good to 5500rpm or get a 2K stall and go for 6000rpm. Just wondering which is the better intake maybe that will help sway my direction.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
