Are these heads any good
Old May 28, 2002 | 04:34 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
I have a set of GM iron heads for my 350ci camaro which came from a drag race corvette.They have manley 3 angle valves,miloden studs,comp cams springs etc and appear to have been extensively re-worked.The casting numbers on them read (as you look at the head from left to right from above)
3978487 GM
L 6 71 34
and as you look underneath there are 2 numbers 487 and 493.
Any help or links to any sites who deal specifically with heads would be much appreciated.
Old May 28, 2002 | 07:07 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
I think you mean these..
3973487....71-72...350..........used on 71-72 350 LT1, 75cc chamber
someone else will have to tell ya on there potential..
Old May 28, 2002 | 08:42 PM
Jester's Avatar
Good is a reletive term. They're pretty decent for stock heads, and the "reworking" can't hurt. So I'd say better than most, but still won't touch a set of good aftermarket heads.
Old May 29, 2002 | 12:52 PM
tpi_roc's Avatar
They'll lower compression.
Old May 29, 2002 | 04:25 PM
Car: '92 RS Camaro
Transmission: TH400
It's OK because the hypereutectic pistons I have will take the compression to 9.5:1 with these heads.Incidentally the (burnt out) car these heads came from had a load of cash spent on it,such as gear vendors under/overdrive unit,TH400 with loads spent on internals,aftermarket injection unit,roller cam,forged crank and pistons,B&M blower and loads more I can't remember.The question is,if a guy has spent that much money on the rest why did he use these heads when he could have used anything?(he wasn't short of a few quid to buy a gear vendors unit).
Old May 30, 2002 | 02:33 AM
ZZsmpch's Avatar
What's a quid?
Old May 30, 2002 | 06:47 AM
Engine: 406
The lb, Its Bloke Money, Somewhere around 2 american $$
I imagine its a little harder to find f-body parts in the ol UK huh....I was stationed at RAF chicksands for 2 years.....I love your country, I have a 19yo daughter who was born there....
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
