Do I need to us lead substitute
Old May 29, 2002 | 08:21 AM
Marks66GTO's Avatar
ok i got a 1966 Pontiac GTO With a 389 tri power the moter rebuilt and bored .30 over and had a 3 angle valve job do i need to use lead substitute? And what happenes if i dont will it cause a prob and what if i didnt use some for a lillte while like 100 miles.
thanks
Old May 29, 2002 | 09:43 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Check with the rebuilder, see if hardened seats were installed...most likely they were on a fresh rebuild. If not, well, FWIW I've put on about 18K miles on my '59's stock 235 head that was last touched in '62...so it definitely doesn't have hardened seats...up to this point I've no ill effects.
Old May 29, 2002 | 10:04 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Just sold my 66 pontiac last year. 325 HP 389.
10-1/2 to 1 CR.
Didn't have any problems with the valve seats, but detonation from 92 Octane Unleaded and hi compression ratio wasted a piston.I'd add a lead substitute as often as possible.
Anything to get the octane up and cool the seats.
A hundred miles without,here and there probably won't matter.
Guy who owned the car before me drove it hard on crappy gas
and the constant hammering it got from the hi compression and bad gas eventually took it's toll. Piston #7 had a hole in it and half the top ring was gone.Amazingly enough, the bore was fine and so were the valves, so I replaced the one piston (std bore)
and it was fine.
Pontiac Motors are beefy!Mine had a ton of hard miles on it and internally it was cherry!
-Rich-
ZEEYAA
Apr 16, 2023 08:29 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
69GTOby
Apr 18, 2016 02:34 PM
ZMWojnar
Interior Parts Wanted
Sep 24, 2015 08:34 PM
