Is backfiring due to excess heat?
Old May 29, 2002 | 06:57 PM
saus89's Avatar
I have an 1989 TBI and it is backfiring thru the TBI. There are no vacuum leaks and the cap, rotor, wires, and plugs are brand new. The base timing is set at 6 degrees TDC. Does anyone knew what could be causing the backfiring? The plugs are one step colder then stock. I only notice the backfiring when the engine gets warm so I suspect that backfiring is caused by to much heat but I am not sure, I have never had this problem before.
Old May 29, 2002 | 07:47 PM
poncho9789's Avatar
Did this start happening right after you put the new cap and rotor in?
If so it could be that the cap you have is cracked and throwing sparks thoroughout the cap causing a misfire.
Did you make shure you got the cap down all the way on the dist?
Trace your wires to make shure you have the right wire going to the right terminal. You could have your wires crossed. causing a misfire.
and make shure your timing is set correct with the EST wire disconnected.
Old May 29, 2002 | 07:51 PM
BAK12484's Avatar
may also want to relash all your valves. My camaro used to backfire all the time... relashed the valves and it's ran good since.
Old May 29, 2002 | 09:51 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Recheck the timing. Check the condition of all the plug wires, make sure there are no cracks.
Old May 29, 2002 | 10:10 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Make sure the the wires go to the correct plug location, i bet you have it off 180 degrees or so!
Vintageracer
Sep 24, 2017 12:34 PM
gixxer92
May 18, 2017 11:20 AM
Veaceonee
Sep 29, 2016 08:15 PM
NZKnight
Oct 15, 2015 02:47 PM
mfp189
Sep 27, 2015 09:25 AM
