I need the Incredible Hulk
Old May 29, 2002 | 10:20 PM
SlowStangEater's Avatar
Ok as you all know I got rearended and I have some binding in my driveshaft and the rearend. Nothing is broke.....So Im assuming its just bent enough to make it bind. My friend told me that all I have to do is get some chains and basically pull it back out. He explained hes done it several times and thats all I would need to do. Besides replace my one seal where my fluid is leaking. Does this sound about right to any of you guys.
Old May 29, 2002 | 11:04 PM
ronterry's Avatar
Car: '94 Corvette
Have you tried rocking the car back & forth by hand while it's in gear.
I can ussualy get the driveshaft to come loose by putting my butt on the bumper, and just start rocking it back & forth a few times.
It's all in the legs
If it's on stands you might even be able to jerk the wheels back & forth on the rear to get it to come loose.
Ron
Old May 29, 2002 | 11:08 PM
Ron
I said I need the Incredible Hulk Not I am the Incredible Hulk J/K I havent tried that. I cant even see where its binding....I can only hear it. But I guess I could try that. Except how can I do it in gear if its a stick??
Old May 29, 2002 | 11:21 PM
ronterry's Avatar
Car: '94 Corvette
That's fine being a stick. Your just going to let the wieght of the car do all the work. It's hard to explain. Just push the car forward, and let it come back on you. It will move a few inches. Just get it going back in forth, and see if that helps any.
Ron
Old May 29, 2002 | 11:27 PM
Ron
Since Igot rearended....wouldnt I want to push the car backwards?
Bubbajones_ya
Jul 6, 2024 08:32 PM
mfp189
Sep 27, 2015 09:25 AM
GoldenSwordZ28
Mar 3, 2002 12:21 PM
Dustin Mustangs
Car Audio
Mar 2, 2002 05:58 PM
Hulk0202
Jul 25, 2001 08:45 AM
