can i lower my car and still keep my long tube headers???
Old May 30, 2002 | 02:12 PM
383LT1intake's Avatar
Car: 92 camaro
Engine: 383 stroker
Transmission: probuilt 700r4
i have hooker super comp lt headers can i lower and still be ok? i was looking at the eibach sport line i think its like a inch drop thanks
Old May 31, 2002 | 01:22 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Dunno about the Sportlines, but I am fairly confident that the Pro Kit won't drop the car too much to cause problems with LTs.... I have the PK on my GTA right now and I have LOTS of ground clearance as is and plan on going with Hooker SC LTs later this summer ($$$ permitting of course).
Old May 31, 2002 | 10:26 AM
BAK12484's Avatar
you *might* be okay... not positive tho
My car is lowered and has shorties on it and it's close to the ground....the Y-pipe might have been able to have been pushed up a little bit more but it'd be a tight fit.
Heres a picture of the clearance I have.... if u can't quite make it out, theres about a finger's width above my hand to the bottom of the Y-pipe
Then again my car is lowered quite a bit... I'm not too sure by how much as when I bought it was already lowered - - I can't even fit a jack under the frame to jack it up; I have to use the jack points on the sides.
1992 Trans Am
May 10, 2023 07:19 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
mustangman65_79
Aug 7, 2015 09:55 PM
drathaar907
Aug 6, 2015 04:20 PM
