Which wire is for the ac compressor.
Old Jun 1, 2002 | 08:42 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Need your intellegence guys,Which wire is for the ac compressor.
Which wire is the power wire for the ac compressor? Is it the black or the green wire that is behind the pulley, or one of the two wires in the back of the compressor?
Old Jun 2, 2002 | 08:03 AM
Vader's Avatar
The two-wire connector at the front of the compressor engages the clutch. The connector at the rear of the compressor is for the high pressure safety switch.
Old Jun 2, 2002 | 10:33 AM
Car: 85 Camaro SC
Engine: V6
So one of the high pressure switch wires will turn the fan on when you turn on the ac right?
Old Jun 2, 2002 | 01:48 PM
Vader's Avatar
"So one of the high pressure switch wires will turn the fan on when you turn on the ac right?"
No. That switch protects the compressor. The fan switch is generally located along he right side of the engine compartment, tapped into one of the refrigerant lines from the condenser.
Old Jun 2, 2002 | 03:43 PM
Car: 85 Camaro SC
Engine: V6
Thanks Vader.
Old Jun 2, 2002 | 04:15 PM
Car: 85 Camaro SC
Engine: V6
Ok I was just looking and saw a connector on one of the lines that has a black and blue wire coming from it, so if it splice with the blue wire my fan should come on.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
rh76camaro
Aug 15, 2015 12:48 PM
