Cooling Pusher Fan in front of radiator (Size, Part Number)
Old Jun 2, 2002 | 07:08 PM
CAMARO82's Avatar
What size could ft in front of my radiator to push air, I've been looking around and I don't want to get the Wrog one, So does anyone have a place and the part number, I hav an 82 Camaro Thanks
Old Jun 2, 2002 | 07:32 PM
89WS-6's Avatar
don't know about this part you are talking about, but your local GM parts dealer could have all the answers for you.
Old Jun 2, 2002 | 08:23 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I just took a pusher fan out of my 82 Z28.
It was a Hayden model# 3690 14" slim-line fan.
I don't think you could get a bigger one in there.
I also have a tranny cooler up there on the pass side of the condensor, so the fan just barely fit on the drivers' side.
My advise would be to skip the pusher fan. It didn't help my eng temp at all in stop and go traffic.
At highway speed, it made the eng run a little hotter (actually blocks air flow).
It did seem to help the A/C a little at idle, but that's abt it.
If you don't have an A/C condensor in the way, the pusher fan might help eng temps a little at idle.
I had to remove the diagonal body brace rods to make room for the fan. That was a mistake. When I re-installed the braces, I really noticed how much the body was flexing without them installed.
Knowing what I know now, I would put the money into a high perf water pump or a heavy duty radiator.
A Stewert (or maybe an Edelbrock) water pump will be my next attempt at getting the temps down at slow speed.
As it stands now with a 3 core radiator, heavy duty 7 blade flex fan, and an external tranny cooler, I still hit over 220 in stop and go traffic with A/C blowing, and have to shift to neutral and hold RPM up to 1500 or so when stopped for any length of time.
At highway speed, it drops to abt 180 or so.
Hope this helps ya a little.
Gotta have this all worked out before July!!
1992 Trans Am
May 10, 2023 07:19 PM
twest2k2
Aug 24, 2015 11:26 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
knight72
Aug 10, 2015 09:32 PM
armybyrd
Aug 10, 2015 09:23 PM
