R-134a retrofit
Old Jun 3, 2002 | 01:08 AM
George Khawahie's Avatar
Car: 1988 Camaro IROC-Z 'Vert
R-134a retrofit
I bought the kit that's made by Interdynamics for $34.99. It comes with all the doohickies to convert to a R-134a setup. I'm going to crack it open and read the manuals and see what’s in store for me. It comes with three 15 oz cans(36 oz of refrigerant and 9 oz of lubricant) of "134a and Oil Charge with Leak Sealer," a tube to connect to the cans, and some little valve dealies.
I don't know how many of the cans I'm suppost to use. They had some other kits that came with guages, but they were for cars already running R-134a. I found this interesting information in the FAQ at Interdynamics website:
Doesn't R-134a need higher pressure to work? Won't that damage my R-12 system?
R-134a systems are designed to run at higher pressure than an R-12 system, which is why we use less R-134a than the amount of R-12 in the system (80-85%). This keeps the pressure at the appropriate level.
The box repeatedly mentions that you have to take the car to get the old R-12 stuff by a "certified mechanic."
Old Jun 3, 2002 | 09:53 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
You'll need to flush the system with a special solvent to get out all the old oil. 134A uses a different type of oil and 2 oil types don't get along.
Check out Aircondition.com
Lots of good info abt 134A conversions.
You'll also need high and low side gauges and a vacuum pump to service your system.
People using those kits without flushing are the ones who keep the professional A/C guys busy.
anesthes
Sep 18, 2015 12:34 PM
apie2546
Sep 4, 2015 03:47 PM
Fox118
Sep 1, 2015 04:07 PM
TPI Guy
Oct 19, 2001 02:37 PM
ArnoldBraker
Aug 20, 2001 04:06 PM
