thinking of swapping to a LT1 intake...
Old Jun 4, 2002 | 06:42 PM
89Irocz23's Avatar
ok guys I got 89 iroc z with a mild 355. Still need to change cam and heads since there stock, but for now its ok...I was just wondering how much would i benefit from a Lt1 intake...im just sick of TPI dying out so early plus i like the way a Lt1 looks. also how much would it be if I bought a intake from john and had him do it. Also I have a edelbrock high flow base then stock runners and ported plenium I want to sell. If anyone is interested.
Old Jun 5, 2002 | 08:46 AM
snakeskinner's Avatar
well, you're looking at extensive mods to get one to work because of the reverse flow cooling design. Plus I don't think any of the bolt holes will line up (might be wrong there). there are no coolant passages in the intake like on a normal smallblock so you'd have to custom fabricate some sort of crossover pipe in some fashion. If you really like the LT1 look, get a TPIS miniram. Not much of a fan of this intake but it looks like the LT1
Old Jun 5, 2002 | 12:22 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
check out www.lt1intake.com
Old Jun 7, 2002 | 07:38 AM
didn't realize someone had went through this trouble. My question is why? Unless you are a good machinist and have tools, I don't see this being very cost efficient for the gains. I'll read through it again when I get more time.
Old Jun 7, 2002 | 10:05 AM
Car: '87 Camaro LT
Engine: 355 L98
Even if you have to pay someone to do the machining it's a great value because you're essentially getting a stealth/super/mini ram for several hundreds less and the performance gain is well worth it. I'm starting the swap to LT1 intake from carb now and I estimate it'll cost around $700 for everything I need (harness, fuel pump, ecm, intake, etc.)
Old Jun 7, 2002 | 11:01 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
It's not really that hard, tools are needed though. The gains are GREAT. You get the Miniram type intake for half the price. An excellant deal IMHO.
Gains are simular to the MR too. I gained 5 mph in the 1/4 mile so I estimate a 40-50 HP at the rear wheels. That is probably 60-70 HP at the crank. TPIS advertises their MR for a 90-110 HP gain (crank) and that's advertising numbers. Not far off huh? And mine are real world numbers, not advertising. I imangine with the right combo I could attain the same 90-110 HP gains too.
What other bolt on will give that kind of power for $500 besides N2O?
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
