Ignition troubles
Old Jun 4, 2002 | 08:49 PM
JR305's Avatar
Ignition troubles
I just finished a bunch of mods on my car and now I can't get it to run correctly. When I am driving the car kind of cuts out and then comes back on, the tack bounces around allot. I seems to start happening when I have been driving the car for a while, ~15 min and gets progressively worse. I know its not the ignition control module, just replaced it today and it did not correct the problem. I have also disconnected my MSD digital 6 unit and ran the stock setup, still no effect. If I hold the key in the start position just before the started engages, the problem goes away.
I have changed my cam, head, intake, and swapped in a Manuel (T56) trans. I am still running on the stock 305 TBI auto chip. Also I have not hooked up the speedo yet.
Any Ideas as to what my problem might be
Old Jun 4, 2002 | 10:49 PM
Stroked-Z's Avatar
I had that prob when I installed my new Strip Annihilator ign box & MSD distributor...
The stock HEI wire i cut (dont need anymore) was touching the block (i had tape on it....stupid me) anyhow it was shorting against it & would cut out the ignition momentarily while the engine ran....
I also found a few more cut wires that were unprotected.......fixed all that up & now i have no probs.
Good Luck, electrical probs are a pain in the azz to find & fix
Old Jun 5, 2002 | 01:57 AM
blk91z28's Avatar
Yea it sounds like you have short somewhere to me also.Thats the worst possible thing diagnose in my opinion.PITA
Old Jun 5, 2002 | 06:45 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
If messing with the switch has an effect, that would be the first place I would look....just a thought.
Old Jun 5, 2002 | 07:38 AM
ronterry's Avatar
Car: '94 Corvette
Yeap, I would drive around with a volt meter hooked up to that ignition wire, and watch for fluctuations.
Ron
Old Jun 5, 2002 | 08:29 AM
JR305's Avatar
Thanks for the responses, I will be going through the wiring today. Could the transmission swap be causing this problem?
When I installed the transmission, I just connected to of the six wires that went to the old auto shifter (green and purple). I have them twisted together so I can start it without fiddling with wires. No on thinks that this might be causing the problem or that I don't have the speedo hooked up. Also, there were two sets wires that plugged into the old transmission, that I have not plugged into the T56.
Stroked-Z... did your problem get worse as you drove the car. With mine I don't have any problems untill I have been driving the car for a while. Then I get a few quick cut outs, followed by a bunch of cut outs.
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
mrbird
Oct 20, 2015 03:43 AM
Lmancha96
Sep 25, 2015 08:11 PM
RedLeader289
Sep 23, 2015 06:50 AM
