help
Old Jun 5, 2002 | 10:56 PM
dbarker02's Avatar
help
ok.. i have this posted in the motor swap board as well, but im not getting any results.
Ok.. I want to ditch almost everything on the car(computer wise)... current setup is listed below. What is the best setup for the least $$ for me to drop in my baby? i need someone else's opinion cause i cant decide on rebuilding it stock dropping a 350 in it :lala: or a big block 454:hail: neways... i only have a couple months to get it running so the faster the project the better. Thanks.
Old Jun 6, 2002 | 07:20 AM
ede's Avatar
ede
carb, intake, and non ecm controlled hei distributor
Old Jun 6, 2002 | 07:44 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
the 350 swap would be pretty simple...the 454...
Old Jun 6, 2002 | 08:30 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'd buy a crate engine. What are your plans performance wise/drivability.
Then like ede said, get an intake/carb/hei distributor.
Not sure if you listed what car you had, if you have an auto, you'll also have to take care of the TC LU.
Old Jun 10, 2002 | 01:11 AM
dbarker02's Avatar
aw well
i found an old 85 caprice that got crunched & had a freshly rebuilt stock 305 just like mine so i grabbed it for 200 bucks.. not a bad buy even at stock specs... now i can rebuild my old one to be a sweet engine & still be able to drive my baby. thanks for all the help guys:rockon:
