what is correct timing
Old Jun 6, 2002 | 08:19 AM
Prem's Avatar
Hi, Can anyone tell me what the correct timing is for a stock 87 GTA with a 350 TPI.
I had a problem where the timing was constantly changing. I managed to find a dist cap for a 305 which looked the same and that solved the problem. But I have to set the timing to about 18-20 degrees BTDC for the car to perform good. Setting it any less causes over heating and hesitation. Is this setting OK.
Prem.
Old Jun 6, 2002 | 09:11 AM
ede's Avatar
ede
i ithnk 6* btdc with the est unplugged, did you unplug the est? it sounds like you never
Old Jun 7, 2002 | 10:35 AM
Vader's Avatar
Unplug the connector and try again. I know that the caps/rotors on '85-'87 TPI engines are different (lower and larger) than those on other V-8s.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Linson
Aug 21, 2015 02:12 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
