TACH jumps at crusing speeds plz help
My tach jumps when i am crusing it deosn't really matter the speed just at constant speed and my engine also misses i just changed spark plugs, sp wires, rotor and distrib i have an 87 305 tpi. I seems to get worse with the amount of timing advance i have, which is advanced pretty far cause i put a new prom and cal pac in there. plz Help
john
john
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
it could possibly be a bad ignition module in the dist. sending a bad reference signal to teh computer. i think that would explain everything. Im assuming you got all new components in teh dist. so that probably isnt it but just a thought.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
