LT1 topend on an older block? Is this possible?
Old Jun 7, 2002 | 11:58 AM
threefiddy's Avatar
I was thinking of swapping the LT1 heads and intake I have on an older bottom end..
Is htis possible or are there problems with the reverse cooling?
Thanks!
Old Jun 7, 2002 | 12:20 PM
AlexJH's Avatar
Engine: 5.7L V8
www.lt1intake.com
Old Jun 7, 2002 | 01:05 PM
threefiddy's Avatar
Originally posted by AlexJH
www.lt1intake.com
Thanks, I have that link. I know I can swap the intake onto the older block, but the main thing I was wondering is if I could swap the heads over also.
Old Jun 7, 2002 | 01:25 PM
Chevy83Z28's Avatar
Don't LT1's have distributorless ignition systems? So in that case... what do you do for ignition?
Old Jun 7, 2002 | 01:58 PM
rezinn's Avatar
Ignition doesn't matter. John Millican has figured that one out. I don't think LT1 heads will work on an old style block, otherwise you'd see them in people's signatures.
Old Jun 7, 2002 | 04:29 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
LT1 heads CAN fit on a standard SBC. RCR was kind enough to scan the write up from a car mag. I copied them to my website.
http://www.lt1intake.com/LT1_retrofit.htm
Old Jun 10, 2002 | 09:12 AM
threefiddy's Avatar
Thank you!!!!!!!!
Old Jun 10, 2002 | 01:25 PM
rezinn's Avatar
They will physically bolt on, but you see that it takes extensive modifications that most of us could not do ourselves for them to work
L0tuS
Oct 4, 2015 08:07 AM
New2Chevy
Sep 28, 2015 12:35 AM
jerflash
Sep 24, 2015 03:11 PM
mygta87
Sep 14, 2015 10:36 PM
L0tuS
Sep 4, 2015 11:16 PM
