Difference between zz3 and zz4 heads
Old Jun 8, 2002 | 12:59 AM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I just wanted to know the difference between assembled zz3 and zz4 heads. Also, will the zz3 head take the springs from the LT4 hotcam kit without machine work? Thanks
Old Jun 8, 2002 | 06:34 AM
e-man's Avatar
Car: 89 formula
Engine: 383
I think its just the springs and retainers that are different.
Old Jun 8, 2002 | 12:23 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
they switched from the gm high performance (orange) springs to the lt4 springs. the lt4 springs are 1.32" diameter. i'm not sure if you will need to open the pockets or not.
Old Jun 8, 2002 | 06:02 PM
You would think they would change the cast if they needed a bigger spot for the springs but you never know. I'll keep looking. Thanks
Old Jun 8, 2002 | 06:46 PM
e-man's Avatar
Car: 89 formula
Engine: 383
Im pretty sure the spring pockets are machined and have a shim under the spring.
lt500r55
Sep 1, 2021 01:30 PM
evilstuie
Jan 9, 2020 08:29 PM
italiano67
Dec 11, 2016 09:21 AM
bamaboy0323
Sep 3, 2015 06:07 AM
