new 1991 z28 ttops 305 tpi v8 automatic all stock!!!! please help
Old Jun 8, 2002 | 12:47 PM
cridom's Avatar
i want to put some upgrades on this car please write a list of what would you buy for this car for example:
1 sfcs
2 hooker catback
3 hooker headers
4 b&m shift kit
5 etc....
and include the price if you know it!!!!!!!!!1
i ran 15.6 at the quater mile is t5hat any good for my car?????(its auto)
Old Jun 8, 2002 | 02:04 PM
Vader's Avatar
Presuming all maintenance is current, you could skip the following list:
Oil and filter change to synthetic (10HP gain and longer engien life);
Replace the fuel filter every 24,000 miles;
Synthetic gear oil in differential (with posi additive is so equipped);
Replace the oxygen sensor every 30,000 miles;
Wheel bearing repack;
Full suspension, chassis, body lube (silicone on bushings, seals, latches, door and roof gaskets, everything in the shop service manual every 15,000 miles);
Transmission flush (to clean oil out of converter as well), filter change, new synthetic oil;
Cooling system flush and refill. A good excuse to change to a 180°F thermostat, too;
Replace belt and old hoses;
Like I mentioned, you've probably already kept that schedule up. In that case, there are some other reasonably priced things you could do:
Convert to AFPR (great on S/D cars for finer tuning);
Port the plenum, intake runners, and intake base;
Change to a free-flowing cat converter and exhaust;
180°F thermostat and fan control;
Install a new roller cam kit (cam, valve springs, lifters, timing chain). This will net more gain than the exhaust system for sure;
Change to a smaller (faster and firmer) servo on the transmission;
If you still have energy/cash left over, think about a higher stall speed torque converter.
Old Jun 8, 2002 | 02:07 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'd get headers and cat-back first. I don't see a need for SFC just yet. I know my car is still fine, but they're coming.
Also, skip the B&M shift kit, it's junk. It does nothing to fix the problems with the 700R4. Get the TransGo Kit, it's the only REAL shift kit.
I'd suggest the Hooker cat-back, paidd $200 for mine, needed some fab to work, the direct bolt up kind is about $260. Sound clip of it is in the signature.
Old Jun 9, 2002 | 01:31 AM
iroc_cragg's Avatar
I have a 305 TPI engine and I have the following mods planned.
- Hooker Headers
- Hooker catback
- K&N filters
- Airfoil
- AFPR
- corvette servo
- Transgo shift kit
- 180 degree stat
- SFC
- STB
- custom ram air (maybe)
- High performance wires
If I were u I would take the car into a high performance garage and get a complete tune up. Make sure it is well done. That should help alot.
Linson
Oct 24, 2025 02:00 PM
FormulasOnly
Jul 23, 2018 08:47 AM
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
