Unsteady vacuum. Start-up one day and I pull 18 Hg, yesterday I only 14. Today 17!
Old Jun 12, 2002 | 09:17 AM
Xenodrgn's Avatar
What gives, what should I look for... A vacuum leak affected by humidity? Or heat? Most of the hoses are new and sealed well. The others don't look bad, what pieces could be bad. Is this related to my lack of working CC?
Throw something at me... engine performance seems to play a hand around this...
Old Jun 12, 2002 | 08:25 PM
Damon's Avatar
Damon
Vacuum is not a constant thing. It will vary DRASTICALLY depending on RPM and throttle postion. Changes from hot to cold will also play with it some. If it runs OK, forget it and move on with life.
Old Jun 12, 2002 | 10:54 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Why are you so worried? Does it not run right? If it is fine i would not worry about it unless the vacuum fluctuates!
Old Jun 12, 2002 | 10:58 PM
RJR99SS's Avatar
yeah, just as a general rule: vacuum at idle is going to be somewhere between 15-22
Old Jun 13, 2002 | 09:10 AM
Xenodrgn's Avatar
I guess I'm a few inches low huh...
Crap, I hate when that happends...
Back to the drawing board.
Old Jun 13, 2002 | 11:52 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
How much vacuum you have at idle depends on several different factors, such as cam, intake, carb, and ring seal. A vacuum of 14 is not low, 8 is pretty low.
project89
Sep 24, 2015 06:38 AM
TheExaminer
Aug 26, 2015 04:59 PM
spaigo
Aug 21, 2015 07:46 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mizz0313
Aug 12, 2015 06:45 AM
