weird spark plug problem
Old Jun 12, 2002 | 01:43 PM
86-red_dawg's Avatar
so i've noticed a lack of power lately - checked all the spark plugs, and they all look good - nice color, no buildup
while doing some coolant work, i cranked it up and had it idleing low - aroun 400 rpms - and noticed a piff piff sound - seemed very constant and around twice a second - hit the gas and the sound went away - i looked down and saw the front sparkplugwire on the driver side moving a bit - sure enough the boot pushed out justbarely with every piff - i'm certain the plug is screwed in all the way, it just seems there is some sort of leak between the cylinder and the boot to force it out slighty - does anyone have ANY idea what this means? tomorrow i'll replace the plug and see if that changes anything...
Old Jun 12, 2002 | 04:07 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
are you sure the plug is tight?
Old Jun 12, 2002 | 04:20 PM
RJR99SS's Avatar
an engine running with a sparkplug loose makes a very noticable noice; which is that piff piff noise you described.
seriously...i'd have doubts as to whether the plug is tight....
Old Jun 12, 2002 | 11:53 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
That's crazy what type of wires do you have?
Old Jun 13, 2002 | 01:03 AM
jeffs82z28's Avatar
Here is a WAG (wild a$$ guess) the porceline, porcelin, porcelien, the hard white thing in the middle of the spark plug may be cracked and allowing combustion pressure up into the boot.
Stranger things have happened.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Feb 28, 2016 03:33 PM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
