timing question
Old Jun 13, 2002 | 01:29 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
timing question
hey guys i advanced my timing a few days ago and the car will haul a$$ under woth but at cruising speeds it seems to jerk back and forth if i decrease the timing it doesnt, but it doesnt seem to get up and go as good, what would cause that? i'm using wp heads and i dont think they're drilled for the egr sensor, i do have the egr sensor in there, but no other emissions.
Old Jun 13, 2002 | 08:38 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Are you using a timing light when you adjust the timing, or just moving the distributor around?
If the latter, you're probably keeping your knock sensor busy. Use a timing light, and only adjust it a couple of degrees at a time. That isn't much movement of the distributor.
The WP S/R Torquer 305's don't have to be drilled for the exhaust cross-over passage.
Old Jun 13, 2002 | 05:21 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
yes i'm using a timing light, i get the egr code after driving on the highway for a while
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
