tune port headaches
Old Jun 16, 2002 | 12:12 AM
boggledinstl's Avatar
tune port headaches
we have two tune port chevrolet cars one is a ta the other a camaro unsure of years.... both are maf cars
one will not start.... new maf new plugs weak fire... will only run if we spray start fluid in throttle body....
the other will start and run at idle will not drive down the road!! new maf in this car as well... codes read a bad maf????
help!!!!!!!! please and thank you
Old Jun 16, 2002 | 12:35 AM
ttt
if anyone knows a spot where i may be able to find answers easier or better please let me know.. thanks
Old Jun 16, 2002 | 01:08 AM
rezinn's Avatar
You could try the tuned port injection board.
Old Jun 16, 2002 | 04:03 PM
Vader's Avatar
Boggle,
Are you still getting error codes? Typically, it is a good idea to inspect/test/replace the MAF power and burnoff relays whenever a MAF error code is encountered.
The first car sounds as if you have a fuel delivery problem. A quick fuel pressure test would answer that.
Need more information/decription on the second one, however.
Old Jun 16, 2002 | 04:32 PM
Amrish's Avatar
the first car u mentioned about not starting unless putting start fluid in hte TB... i had the EXACT problem... the fuel pump was gone...
there isnt any fuel being delivered... check into that, i believe that it the solution to ur prob cause i had been there
Old Jun 16, 2002 | 06:26 PM
BOTTLEDZ28's Avatar
Transmission: A4
I agree with Vader on fuel pressure on first car. does the car stay running after you spray fluid in it?
second car, when does it die, after you start driving or when it does into gear.
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
mrestrictrplate
Sep 21, 2015 11:24 AM
eustodp
Sep 20, 2015 05:09 PM
m00n420
Sep 11, 2015 02:39 PM
