Is the GMPP ZZ4 intake manifold a good upgrade over stock?
Old Jun 16, 2002 | 07:22 PM
firestorm's Avatar
Car: Firebird
Engine: LG4
I'm looking for an emissions legal intake. Is the GMPP ZZ intake manifold 10185063 a good upgrade over the stock LG4 intake? I can get it for $155, which is how much an edelbrock egr maniifold is.
Here's what GM says:
"This manifold is used on all ZZ series 350 HO engines and also can be used on all small-block Chevrolet's thru 1986. This aluminum manifold produces the same horsepower as the previous high-rise design, but provides increased hood clearance and more versatility. It has a dual-pattern flange that can accommodate both standard-flange Holley and spread-bore Quadrajet four-barrel carburetors. This manifold has provisions for all late-model accessory brackets, EGR (exhaust gas recirculation), and an integral hot air choke. A heat shield can be mounted
underneath the manifold to prevent coking when EGR is used."
Old Jun 16, 2002 | 07:40 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I'm not sure if it's better but I sold my intake off of the ZZ4 I bought for like $50 used on this board. I went with TPI on the ZZ4. Keep an eye on the boards for a used intake, they pop up quite frequently.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
