Rebuild parts list
Old Jun 18, 2002 | 11:25 AM
Dragon's Avatar
Rebuild parts list
I'm tearing down an old 350 and turning into a high hp 383 (425-450hp) and I'd like some opinions on the parts I'm leaning towards getting. It will be going into what I plan to be a street legal (barely) racer
-Eagle or Scat 4340 forged crankshaft (3.75" stroke)
-Eagle or Scat 6" 4340 forged connecting rods (btw, which r better, I or H beams rods)
-JE or SRP pistons
-Holley Street Avenger 770CFM carb
-Holley SysteMAX Kit (claims 425 hp/425 ft-lbs on a 350 on the dyno)which includes, intake manifold (idle-6500rpm), Lunati camshaft (Intake .473"/290° @ .006", 105° centerline; Exhaust .488"/297° @ .006", 115° centerline), and aluminium heads (intake runner 215cc, exhaust runner 68cc, 66cc combustion chamber)
-if I don't get the SysteMAX kit, I'll probably run a slighlty more aggressive cam from Comp Cams, Edelbrock Performer RPM Airgap intake manifold and either Dart Pro1 or Holley heads
Any and all opinions are appreciated
Old Jun 18, 2002 | 11:34 AM
ede's Avatar
ede
i'd run more cam and i'd run a lunati. i like i beam rods, look at the weight and consider the lighter, also look for rods that use a bolt instead of the bolt and nut and i'd go 6" rods. big part of the equation is what do you want this engine ot do for you.
Old Jun 18, 2002 | 11:45 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I would run a roller cam with more lift, say .535 & about the same duration & Holley 750cfm, Edelbrock single plane. H beams are little stronger than I beam & will give good clearance on stroker engines. I beams with bolts threaded from the bottom up will work too, for clearance.
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
