gear ratio
Old Jun 18, 2002 | 01:56 PM
loneoner's Avatar
gear ratio
I currently have a 3.08 gear ratio on my 91 camaro rs 305 m5. My max RPM on 4th gear is 3000 and 70 MPH. I would like to increase it to 4 or possibly 5000 RPM's. I am think of changing the ratio to 3.73 or 4.10. Do you have any suggeations on which one is better and if there is any other alternative besides and engine swap?
Old Jun 18, 2002 | 02:31 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
just changing your rearend ratio will not instantly give you top speed
several things comeinto play.
In most case, a 3.42 or 3.73 is the best depending on mods and top end desired. See if you can find an old IROC rearend and swap the entire thing out.. then go from there.
Old Jun 18, 2002 | 05:43 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If you want a 3.42, you could look at the 85-89 2.8 V6 Firebirds & Camaros with automatic transmissions. They got a 3.42/open/drum axle- and the axle is the same strength as a v8 axle of the same year.
Old Jun 18, 2002 | 06:09 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Match your gears to your cam's powerband.
Hotrodboba400
Dec 10, 2019 07:07 PM
88rscamar0
Sep 23, 2015 09:08 PM
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
