Push button starter
Old Jun 19, 2002 | 11:00 AM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
Push button starter
Anyone have a push button to engage their starter? My key cylinder will turn to the "on" positon but not past it to engage the starter. So I was thinking of a push button, which might be kinda cool anyway. Anyone have pics? What kit did you buy or did you make your own?
Old Jun 19, 2002 | 11:14 AM
rezinn's Avatar
I borrowed one last weekend. Basically it just connects the wiring from the battery to the small post on the solenoid(If you use where the battery connects as 12 o'clock, the small post is at about 3 o'clock). Can't be too hard to make, just make sure the button you get and the wiring will hold up.
Old Jun 19, 2002 | 12:01 PM
ede's Avatar
ede
my iroc had one mounted under the stearing column. i have one in my 85, but it's on a switch panel with 5 other switches for the fuel, ignition, water pump, fan, and oil cooler fan... not exactily a stock set up. hell my car doesn't even have a key
Old Jun 19, 2002 | 12:47 PM
ATOMonkey's Avatar
I do it's easy to do. Pep Boys/Auto Zone.... Sells the momentary switch that you need.
RedLeader289
May 28, 2019 01:47 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
