Fuel Pumps
Old Jun 19, 2002 | 05:02 PM
Dragon's Avatar
Fuel Pumps
What criteria are important when deciding on flow rate for a fuel pump?
Old Jun 19, 2002 | 11:17 PM
Joshua Leslie's Avatar
Gallons per hour, and PSI....it all depends on what your motor needs, a typical carb. setup will use need around 6psi, fuel inj. can run anywhere from 12-50, the GPH all depends on how much HP you are making. 1 GPH at 6PSI may be good for a 1HP lawnmower, but for a large V8 you would most definitley need more.
P.S, are you Dragon from Howstuffworks?
Old Jun 20, 2002 | 10:03 AM
Dragon's Avatar
not the Dragon from HowStuffWorks. You might know from such message boards as jbody.org, clubrsx.com and gmpower.net though
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
