attn vader or clutch experts
Old Jun 20, 2002 | 10:34 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
ok as you probably dont remember i installed an autozone clutch and a new flywheel and ever since i get a vibe at 2300 rpms well i took that piece of crap out today is there anything i should look for that may cause the vibes? i'm gonna have the flywheel turned, will they be able to check the balance on it? also i want to get the centerforce dual friction clutch, and a roller pilot bearing, tranny input shaft is fine, am gonna take the top off to check things out again.
Old Jun 20, 2002 | 01:27 PM
iroc22's Avatar
Always make sure there's no oil leaks coming into the bell housing.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
djmarch
Oct 2, 2015 10:41 PM
mfp189
Sep 27, 2015 09:25 AM
