Small problem need some help
Old Jun 21, 2002 | 07:43 AM
Nephilim's Avatar
There is oil starting to settle on the intake and when my car is driven for a while then i stop smoke comes out of the hood and it seems like it might be the Valver Cover gasket? anyone have any info on this? thank you
Old Jun 21, 2002 | 12:46 PM
Jza's Avatar
Jza
Usually that's a very good sign your valve cover gasket needs attention. Oil on the intake is usually either caused by that, or from oil creeping up the intake bolts. Smoke from under the hood would probably be the oil seeping from the other side of the gasket onto the exhaust manifolds where it's promptly burned.
Try to get the rubber gaskets instead of the cork ones. They aren't as messy to use/remove, and I've never had a leak with one.
Old Jun 21, 2002 | 01:53 PM
iroc22's Avatar
I'm sure it's a valve cover gasket. The smoke is from oil falling onto the exhaust manifolds.
I wouldnt recommend rubber. It relaxes over time and fails sealing. I would recommend ROL hi-performance blue (or equivalent), which is a composite and acts like rubber and cork at the same time.
Old Jun 21, 2002 | 05:52 PM
Nephilim's Avatar
Thanks where do i get those blue ones? i called a local auto parts store and all they have is Cork and rubber
jhawkeye
May 25, 2022 06:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
theshackle
Mar 5, 2017 06:37 PM
db057
Aug 22, 2015 08:17 PM
theurge
Aug 21, 2015 12:46 PM
