383 w/o clearance work
Old Jun 21, 2002 | 06:16 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I've seen a couple of posts recently that mention 383 stroker rotating assys that don't need any block clearance work.
I'm currently searching for parts to build a 383, and if there are parts out there that don't require block machining I would be very interested.
Old Jun 21, 2002 | 07:24 PM
Fast3rdGen's Avatar
i very seriously doubt you'll be able to build a 383 without clearance work on the block. i had a TON of grinding to do on mine when i built it. something like 16 places on the block needed ground.
Old Jun 22, 2002 | 09:07 PM
boogie's Avatar
The only time I have gotten away without having to grind for clearance was with the use of 5.56 400 rods and off the shelf 350 pistons.
Lonnie
Old Jun 23, 2002 | 12:01 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Thx for the replies guys!
Any one else?
I'll be needing to buy parts soon.
The machine shop called and they need my pistons to bore/hone the cyls.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
sreZ28
Aug 14, 2015 07:48 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
