hard to start
Old Jun 24, 2002 | 12:29 PM
eres88's Avatar
Hard to Start. Please Help.
I've got a 5.7 TPI 1988 Iroc-Z that I have to crank much longer than I probably should to start.
If I let the car sit for several days, the first time I try and start it, it fires immediately. If I've been running it, and it's still at operating temp, it fires immediately.
If it starts to cool down, or sits overnight, it doesn't seem to really ever "fire", it just cranks until until the RPMs are over 500, then I can let off the starter and it'll idle. I can smell gas when it starts like this. None of the plugs seem to be overly fouled. I've had it in the shop half a dozen times for this and I've had the MAF sensor replaced twice, had the "computer" (ECM ?) replaced, and have had most of the wiring checked.
Has anyone experienced anything like this or have any ideas on what the problem can be?
Thanks in advance for the assist,
Eres
Old Jun 25, 2002 | 08:29 AM
Vader's Avatar
Eres,
The protracted cranking could be a result of the fuel pump not priming, but that normally causes harder starts after the engine has been sitting for a couple of days, not the other way around.
Try a fuel pressure test to determine if the injectors are leaking down.
Old Jun 25, 2002 | 08:44 AM
chevyguy1969's Avatar
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
Sounds like the sme demon I am chasing Eres. Check out my thread.
https://www.thirdgen.org/techbb2/sho...hreadid=115225
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
