Pulled out a plug that looked like...
Old Jun 24, 2002 | 05:03 PM
86IROCZ's Avatar
this...
only one plug looked like this, all the other ones were normal. What conditions would cause this and why would they only occur in one cylinder? (it's #1 if that's important)
Thanks.
Old Jun 24, 2002 | 05:50 PM
gpierce's Avatar
I think the only thing that would cause that is detonation. Improper timing, too low octane, or not enough cooling to that cylinder can all be reasons for that.
GP
Old Jun 25, 2002 | 12:04 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
gpierce pretty much covered it, the temps get too hot and the fuel/air mixture pre-ignites, will often cause serious damage to an engine. If you have a lot of carbon build up in your cylinders it may be retaining enough heat to do that. if you have higher than stock compression you should probably be using premium.
Old Jun 25, 2002 | 12:55 PM
86IROCZ's Avatar
Thanks guys! Maybe there is enough build up in that cylinder to cause this. Possibly a bad valve? I notice that it idles rough, apparently at random. That's why i checked the plugs in the first place.
87yellowirocz
Exterior Parts Wanted
Oct 23, 2015 09:52 PM
R3500
Aug 17, 2015 12:16 PM
BikeFarm
Aug 11, 2015 11:35 PM
L98GTA87
Aug 11, 2015 06:55 PM
mustangman65_79
Aug 7, 2015 09:55 PM
