350 heads
Old Jun 24, 2002 | 09:35 PM
dheck's Avatar
350 heads
Can anyone tell me what the stock specifications on pre '86 350 heads are. I am not really sure what they came out of or if that even matters. I need to know valve sizes, cc's, valve lift, ect.
Old Jun 25, 2002 | 01:31 AM
Guest
Guest
Posts: n/a
Basically an impossible question to answer, given the information you have.
Get the casting number off the heads. You can go to www.mortec.com and there it'll tell you where to look and quite likely what they are after you get the number. Otherwise it would just be a guessing game.
Old Jun 25, 2002 | 01:56 AM
rezinn's Avatar
Valve lift isn't a head specification, it's calculated using camshaft lobe height and rocker arm ratio.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
NWAsonoma
Aug 18, 2015 05:45 PM
