Forged aluminum rods
Old Jun 24, 2002 | 10:50 PM
LugNutZ's Avatar
Does anyone have a good idea of how many horsepower a set of Manley forged aluminum rods can handle reliably?
Old Jun 25, 2002 | 01:27 AM
urbman's Avatar
The way to think about this is in terms of the force you expect them to contain. That is for a given crank throw and piston
weight ... how fast can you spin them and how long
can you get away with it.
Roughly ....
1. Determine the duty cycle...
Is this a 24hours engine, 500 miler, drag racer
(aluminum rods are usually for drag racing)
2. Figure out the bore and stroke and piston configuration
of what you are trying to build
3. Determine how fast this has to spin to meet your target
(7000rpm for a 10 sec National final or 50 passes at 6000
local club racing)
Now you will have something to talk to Manley about...
Old Jun 25, 2002 | 07:24 AM
ede's Avatar
ede
HP usually isn't a problem but they don't live for long on the street
Old Jun 25, 2002 | 11:19 AM
LugNutZ's Avatar
Alright, thanks. I was just curious about them. I've never dealt with or looked into them before. Thanks for the help.
Old Jun 25, 2002 | 02:54 PM
goneracin's Avatar
Alum rods are a bad idea on the street. Alum will work harden with repeated cycles, and the temp seen on the street will also shorten their life. When it stretches at the top of each exhaust stroke, it will then come back to its orriginal length, for a certain amount of cycles. Many cycles lead to its work hardening, and when it reaches its limit, it will break. Hp is not a factor at all, we use them in engines making in excess of 2000 hp on nitrous, and also in 9500 rpm 500 inch engines, but we also consider about 40 passes the limit, then throw them away. Id stick with a good steel rod for serious street use. Just my .02 worth.
Hotrodboba400
Dec 10, 2019 07:07 PM
Nervous2
Oct 8, 2015 10:53 PM
evilstuie
Sep 24, 2015 12:04 AM
TOMcat GTA
Sep 15, 2015 09:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
