New Car...NEED HELP!!!
Old Jun 25, 2002 | 02:32 PM
CarNDrvr's Avatar
Hey guys. Well, I have been carburated my whole life, and now I am both blown and fuel injected in my 1990 Vette. I know it isn't a 3rd gen, but I know most people on here and they know me, and the L98 should be the same as everyone else's. Here are my questions:
1) Do I have to do any modifications to put 1.6 roller rockers on...new springs, pushrods, valve cover modification, etc...and it is worth the horsepower gain?
2) I went to the dyno recently and found out that I am running WAY too rich. My A/F ratio is 11.2 to 1 at idle and drops off the chart under heavy acceleration. Then it comes back up and gets up to 14 to 1 around 4900rpm. I talked with some chip burners and they said they can make all the adjustments to fix that. They said I need a scanner to monitor a few things and make a few settings...like throttle position. What do I need and where do I get it?
Just so you know, my base timing was set at 0, the car was 210 degrees, and my mixture was way too rich, and it made 348rwhp/390rwtq. Anyone who can help me out in this area would be greatly appreciated.
You can read my new sig to see what all the car has.
Old Jun 26, 2002 | 12:26 AM
89WS-6's Avatar
you should make more HP with a setup like that. But roller rockers always help. At least you could do a factory replaceent. For example, if your rocker arms are 1.5:1, then buy some 1.5:1 rollers. And have no worry about it. That's my advice.
CustomX
Jun 5, 2003 08:04 AM
i8urrice
Carburetors
20
Jun 5, 2002 09:14 AM
