Go For It !!!!!!!
Old Jun 29, 2002 | 08:16 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
Go For It !!!!!!!
THAT CAM ISN'T TOO BIG WITH A CUSTOM CHIP....... AFR USED THAT EXACT CAM PART 12-433-8 WITH THEIR 190CC STREETS AND PULLED 503HP AT 5500RPM AND 517FLTLBS AT LIKE 4500 RPM... THAT IS THE EXACT SAME CAM I AM GOING WITH AND THINK IS THE BEST.... PM ZEPHER AND HE CAN BURN YOU CHIPS CHEAP.... ID RUN 26LB INJECTORS JUST TO MAKE SURE IT DOSEN'T RUN LEAN WITH THOSE HEADS.....
P.S. ROAST THEM SONS A BITCHES!!!
