Need to hookup my electronic choke
Old Jul 2, 2002 | 02:36 PM
uidzer0_z28's Avatar
Hey guys,
I just got done converting my cfi system to carb. I got the edelbrock 1406 600cfm carb with an electric choke, does anyone know where I can hookup the power so that it is only on when I turn the ignition key?
Thanks!
Ben
Old Jul 2, 2002 | 06:05 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Yeah, any keyed, switched device in the fuse panel.....If the device works only when the key is on...it will work.
Old Jul 3, 2002 | 10:43 AM
Vader's Avatar
The factory E4ME electric choke was usually connected to ignition power through an auxilliary oil pressure switch, so the choke heater only operated when the engine was actually running. This proved best for cold weather operation.
Old Jul 3, 2002 | 01:26 PM
Not sure what I hooked it up to but I found a red wire coming out of the fuse panel so I spliced it and hooked it up to that, seems to work just fine.
-Ben
InfernalVortex
Apr 20, 2021 11:31 AM
MrPackstin
Oct 25, 2017 08:09 PM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
anesthes
Sep 30, 2015 07:48 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
