would a busted timing light
Old Jul 2, 2002 | 11:57 PM
cacktopher's Avatar
NOT light up when u hook it up to a power source? I borrowed a friends timing light, and i'm trying to adjust my timing for the first time. A yes or no answer would really help me out.
Old Jul 3, 2002 | 12:01 AM
J's86ROC's Avatar
Car: 1986 IROC-Z
Engine: peanut cam LB9
If it the bulb or the wiring inside is damaged then no I wouldn't think it would light up.
Old Jul 3, 2002 | 12:02 AM
cacktopher's Avatar
much appreciated. i never used a timing light. i was thinking i was doing something wrong. thank you.
Old Jul 3, 2002 | 12:18 AM
Jza's Avatar
Jza
It's gotta have a trigger. Most are inductive... ei it has a lead that clamps over a wire (#1 spark plug wire) and can tell through the insulation that there's current going through it to trigger the light. But some have to be plugged inline with the sparkplug. You did hook up the trigger lead as well as the power and ground leads, right?
Old Jul 3, 2002 | 10:42 AM
cacktopher's Avatar
yes i did. i hooked up one of the clamps to the number one spark plug wire. I pushed the button and nothing happened. I started the car to see if that would do anything and no light or anything.
Andrew6.688
Dec 13, 2015 10:59 AM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Omega
Aug 10, 2015 12:46 PM
Thirim
Aug 9, 2015 06:19 PM
