Q-Jet Question
Q-Jet Question
Can anyone[pref. someone with similar set-up]give me a good starting point for rods,jets and hanger. A 310cu.in. sbc with Q-jet, weiand 8004, gm 87 alum. vette heads,crane cam hyd 216/454,mallory ign; dual stk. exh. w/dynomax hemi turbos,appox. 9.5:1 compression.This is going in a s-blazer with 2004r trans and 3.42 zexel.
Transmission: 4L80E/4L80E
If you asked this question on the carb forum, you'd probably be told, "DR rods, G hanger."
Sorry, that was uncalled for.
The carb forum has several posts on the topic. Basically, that's a good place to start, you can tune the hanger and AV from there.
