Need Help with Piston to Valve Clearance!!
Old Jul 4, 2002 | 04:34 PM
92camaro's Avatar
I have a 1992 Camaro and I am about to install a 350 with TRW flat top pistons with a Comp Cam Magum 292 cam with Trickflow cylinder head, victor jr intake and a Demon 750 carb. I was wondering if I would have any problem with piston to valve clearance. The cam spec on 244 @.050 on intake and exhaust and 501 lift on a 110 ls. I checked with clay and everything look good put I am just wanting to see if anyone else had run the combo. Thanks
Old Jul 4, 2002 | 05:00 PM
ede's Avatar
ede
if you've already checked it then you should already know the answer. i usually indicate 2 valves to check clearance, but clay works. i've never saw anything close till around .650 lift
Old Jul 4, 2002 | 05:11 PM
92camaro's Avatar
I did check but I was wanting to see if anyone ran something close to mine. Does to see how it checked. Thanks
db057
Apr 28, 2019 07:45 AM
New2Chevy
Sep 28, 2015 12:35 AM
355tpipickup
Sep 13, 2015 11:35 PM
Nick McCardle
Sep 10, 2015 08:36 PM
