Must I use a HR camshaft in a roller block, or can I use a regular hydraulic one?
I will sacrifice a few HP to cut a couple hundred dollars in cost.
If I have to use a HR camshaft, what is my best bet for an emmissions legal camshaft that won't chug gas for breakfast?
Transmission: 4L80E/4L80E
You can use flat tappet. You'll need a set of non-roller pushrods to go along with the cam, lifters and timing set.
The Crane computer compatible cams are pretty nice. I got 18 mpg on my last tank of commuting (and more than a few on-ramp test sessions).
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
RyanJB
Sep 14, 2015 03:39 PM
